packetwerks
Apr 02, 2018Star
v2.1.3.4
My Orbi autoupgraded to v.2.1.3.4 this morning and I found tht ethernet backhaul no longer works. Is this expected behavior? Anyone else seeing this?
Apr 02, 2018Guru - Experienced User
Do a full factory reset on both router and satellite then set up from scratch with ethernet back haul.
Anonymous
Apr 02, 2018when you do a factory reset, does the Orbi/Sats reload the current FW?
