packetwerks
Apr 02, 2018Star
v2.1.3.4
My Orbi autoupgraded to v.2.1.3.4 this morning and I found tht ethernet backhaul no longer works. Is this expected behavior? Anyone else seeing this?
Apr 02, 2018Guru - Experienced User
Should clear out all user configurations is all.
I'm seeing a problem of upgrading to newer versions of FW and older configurations or older code inhibiting good operation. After a factory reset, seems to clear out these problems and gets the code working properly. I believe this is a bug.
