packetwerks
Apr 02, 2018Star
v2.1.3.4
My Orbi autoupgraded to v.2.1.3.4 this morning and I found tht ethernet backhaul no longer works. Is this expected behavior? Anyone else seeing this?
Apr 02, 2018Guru - Experienced User
Should clear out all user configurations is all.
I'm seeing a problem of upgrading to newer versions of FW and older configurations or older code inhibiting good operation. After a factory reset, seems to clear out these problems and gets the code working properly. I believe this is a bug.
jangno
Apr 02, 2018Aspirant
I have a 3pc Orbi AC3000. For some reason, only one of the RBS50 satellites finds the new firmware v2.1.3.4. The other RBS50 and the RBR50 both say there is no new firmware version available. I assume that all 3 components need to run the same version though. I considered manual update, but I can't figure out where to download 2.1.3.4.
- Retired_MemberApr 02, 2018
- FURRYe38Apr 02, 2018Guru - Experienced User
I don't think v2.1.3.4 is posted on the dowload site as of yet. :smileywink:
Retired_Memberwrote:http://downloadcenter.netgear.com/
- tagteamApr 02, 2018Virtuoso
Yes, v2.1.3.4 is posted on the download site and is apparently being pushed through by NG.
I checked this morning via the UI and there it was (although I haven't installed it yet).
From here:
Users of 50 series models are encourages to upgrade to this version of FW.
Please do a factory reset on both router and satellite(s) after loadings this version of FW and setup from scratch.
jangnowrote:I have a 3pc Orbi AC3000. For some reason, only one of the RBS50 satellites finds the new firmware v2.1.3.4. The other RBS50 and the RBR50 both say there is no new firmware version available. I assume that all 3 components need to run the same version though. I considered manual update, but I can't figure out where to download 2.1.3.4.
