packetwerks
Apr 02, 2018Star
v2.1.3.4
My Orbi autoupgraded to v.2.1.3.4 this morning and I found tht ethernet backhaul no longer works. Is this expected behavior? Anyone else seeing this?
Retired_Member
Apr 02, 2018Thanks...In my case I'm running the Orbi/Sats with all default settings. I've not made any changes.
Apr 02, 2018Guru - Experienced User
If you experience any problems after upgrading FW, do a reset. I presume those problems should go away.
Also, after a reset and set up again, do a new save config file. I also found that using older saved config files cause problems with newer FW versions. So save off a new one.
