packetwerks
Apr 02, 2018Star
v2.1.3.4
My Orbi autoupgraded to v.2.1.3.4 this morning and I found tht ethernet backhaul no longer works. Is this expected behavior? Anyone else seeing this?
Apr 02, 2018Guru - Experienced User
Review and collect files here if you want to manually upgrade again yourself:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1533584/highlight/true#M26234
Has info on how to upgrade. Start with the Satellite first then router.
Reset both units after upgrading FW and setup from scratch. Set up the router first, then Satellite on wireless. Once these are running good. Connect the ethernet cable to the Satellite from the router. Give at least 5 minutes for the system to re-configure for wired back haul.
This is how I got mine working.
jgehlhaarwrote:
FURRYe38wrote:Im seen a mixed bad of users saying there units are working after the upgrade with out a reset and some other users still exhibiting problems after the upgrade and not doing a reset. After asking them to reset both units, there problems seems to have been resolved. I saw an issue as well in my presonal testing.
And the factory reset fixes the wired backhaul issues? So if I have a setup working and want to try this, how do I do a factory reset and load the latest firmware? Some tech note that covers all of that?
Thanks!
- Jeff
jgehlhaar
Apr 02, 2018Aspirant
FURRYe38wrote:Review and collect files here if you want to manually upgrade again yourself:
Reset both units after upgrading FW and setup from scratch. Set up the router first, then Satellite on wireless. Once these are running good. Connect the ethernet cable to the Satellite from the router. Give at least 5 minutes for the system to re-configure for wired back haul.This is how I got mine working.
Thanks!
- Jeff
If latest firmware is kept loaded in the device even during factory reset, so just reset and reconfirgure everything?
- FURRYe38Apr 02, 2018Guru - Experienced User
Yes, reset both units and set up from scratch. Walk thru the set up wizard.
- jgehlhaarApr 02, 2018Aspirant
I've seen some posts that indicate this works for a while then flakes out with ethernet backhaul. Can folks confirm it seems stable?
I assume clients don't need to be reconfigured if you put SSID and password back to current settings?
- Jeff
MInes been working since v2.1.3.x. I just upgraded again. Still stable for me.
You can use same SSID and PW if you had been using that before.
