packetwerks
Apr 02, 2018Star
v2.1.3.4
My Orbi autoupgraded to v.2.1.3.4 this morning and I found tht ethernet backhaul no longer works. Is this expected behavior? Anyone else seeing this?
Apr 02, 2018Guru - Experienced User
Yes, reset both units and set up from scratch. Walk thru the set up wizard.
jgehlhaar
Apr 02, 2018Aspirant
I've seen some posts that indicate this works for a while then flakes out with ethernet backhaul. Can folks confirm it seems stable?
I assume clients don't need to be reconfigured if you put SSID and password back to current settings?
- Jeff
- FURRYe38Apr 02, 2018Guru - Experienced User
MInes been working since v2.1.3.x. I just upgraded again. Still stable for me.
You can use same SSID and PW if you had been using that before.
