packetwerks
Apr 02, 2018Star
v2.1.3.4
My Orbi autoupgraded to v.2.1.3.4 this morning and I found tht ethernet backhaul no longer works. Is this expected behavior? Anyone else seeing this?
Apr 02, 2018Guru - Experienced User
Do a full factory reset on both router and satellite then set up from scratch with ethernet back haul.
packetwerks
Apr 02, 2018Star
Factory reset router and satellites. I wasn't able to reload the old config as it would make the router disappear from the wired side (e.g. it's old static IP wasn't reachable). So treated it like a new install. Got all satellites sync'd but one wouldn't use wired backhaul - only 5Ghz. So now trubleshooting that.
