packetwerks
Apr 02, 2018Star
v2.1.3.4
My Orbi autoupgraded to v.2.1.3.4 this morning and I found tht ethernet backhaul no longer works. Is this expected behavior? Anyone else seeing this?
packetwerks
Apr 02, 2018Star
Factory reset router and satellites. I wasn't able to reload the old config as it would make the router disappear from the wired side (e.g. it's old static IP wasn't reachable). So treated it like a new install. Got all satellites sync'd but one wouldn't use wired backhaul - only 5Ghz. So now trubleshooting that.
Apr 02, 2018Guru - Experienced User
OK, swap satellites around to see if the problem tracks or not..
- packetwerksApr 02, 2018Star
I'll give that a try.
Question: Does the LAN port on the back of the router and/or satellite matter for wired backhaul? Out of habit I always put the connection to my switch (what I want to be the backhaul) in the LAN port closest to the power plug.- FURRYe38Apr 02, 2018Guru - Experienced User
No doesn't matter. Switch will route the traffic the same way on any LAN port.
I can't move the sat now but I did notice that two identical (hardware) satellites have different interfaces:
Wired Backhaul working:
bridge name bridge id STP enabled interfaces br0 8000.9c3dcfe5a291 no ath0 ath01 ath02 ath1 ath2 ath21 eth0 eth1Wired Backhaul not working:
root@RBS50:/# brctl show bridge name bridge id STP enabled interfaces br0 8000.9c3dcfe58e41 no ath0 ath01 ath1 ath2 eth0 eth1 brwan 8000.000000000000 noAny idea why one satellite would start with different interfaces?
