packetwerks
Apr 02, 2018Star
v2.1.3.4
My Orbi autoupgraded to v.2.1.3.4 this morning and I found tht ethernet backhaul no longer works. Is this expected behavior? Anyone else seeing this?
Apr 02, 2018Guru - Experienced User
No doesn't matter. Switch will route the traffic the same way on any LAN port.
packetwerks
Apr 02, 2018Star
I can't move the sat now but I did notice that two identical (hardware) satellites have different interfaces:
Wired Backhaul working:
bridge name bridge id STP enabled interfaces br0 8000.9c3dcfe5a291 no ath0 ath01 ath02 ath1 ath2 ath21 eth0 eth1
Wired Backhaul not working:
root@RBS50:/# brctl show bridge name bridge id STP enabled interfaces br0 8000.9c3dcfe58e41 no ath0 ath01 ath1 ath2 eth0 eth1 brwan 8000.000000000000 no
Any idea why one satellite would start with different interfaces?
- FURRYe38Apr 02, 2018Guru - Experienced User
Where is
8000.9c3dcfe58e41
connected too? Directly to router or 1st Sat?
Is Daisy Chain enabled or disabled?
I would test this one Sat alone directly with the router, with the others turned off temporarily and see what happens.
- packetwerksApr 02, 2018Star
Daisy chain is enabled. Router is in AP mode, both satellites and router are connected to eachtoher via a GigE switch.
Ah, now that I look at it, the satellite where wired backhaul isn't working (basement) is connected to the working backhaul satellite (office). I'll disable daisy chain now and see what happens. Thanks for the help.
