packetwerks
Apr 02, 2018Star
v2.1.3.4
My Orbi autoupgraded to v.2.1.3.4 this morning and I found tht ethernet backhaul no longer works. Is this expected behavior? Anyone else seeing this?
Apr 02, 2018Guru - Experienced User
Where is
8000.9c3dcfe58e41
connected too? Directly to router or 1st Sat?
Is Daisy Chain enabled or disabled?
I would test this one Sat alone directly with the router, with the others turned off temporarily and see what happens.
packetwerks
Apr 02, 2018Star
Daisy chain is enabled. Router is in AP mode, both satellites and router are connected to eachtoher via a GigE switch.
Ah, now that I look at it, the satellite where wired backhaul isn't working (basement) is connected to the working backhaul satellite (office). I'll disable daisy chain now and see what happens. Thanks for the help.
