packetwerks
Apr 02, 2018Star
v2.1.3.4
My Orbi autoupgraded to v.2.1.3.4 this morning and I found tht ethernet backhaul no longer works. Is this expected behavior? Anyone else seeing this?
SOG1996
Apr 02, 2018Aspirant
The whole day wasted on trying to get my home netowrk back in business, this firmware is causing the router to reboot every 2-3 minutes. we definitly need the option in the app to stop auto update in the ORBI routers and Satelites
Apr 02, 2018Guru - Experienced User
Did you do a factory reset on both router and Satellite(s) then set up from scratch. Were seeing continued problems after the FW is updated and needs a full factory reset and set up again. Others have reported this and reported that after the reset, seems to clear the problems.
SOG1996wrote:The whole day wasted on trying to get my home netowrk back in business, this firmware is causing the router to reboot every 2-3 minutes. we definitly need the option in the app to stop auto update in the ORBI routers and Satelites
- SOG1996Apr 02, 2018Aspirant
I did not wanted to do it at first because I label every device that connects to my network 120 of them, but as last resource I did reset the router & Satelite juts to find out it did not make any difference, router kept rebooting every 2-3 minutes, I fell back to V2.0.1.4 but I know it I will get the auto update some time in the near future.
- FURRYe38Apr 02, 2018Guru - Experienced User
So is v2.0.1.4 working with out any problems?
When you did the factory reset on v2.1.3.4, did you set up from scratch or apply a saved config file?
SOG1996wrote:I did not wanted to do it at first because I label every device that connects to my network 120 of them, but as last resource I did reset the router & Satelite juts to find out it did not make any difference, router kept rebooting every 2-3 minutes, I fell back to V2.0.1.4 but I know it I will get the auto update some time in the near future.
from scratch, went thru the whole thing, entering the App admin ID/PSW, the ssid and netowok psw, I had to set up my guest network, and like I said before I lost all the set up I had where I label each devide , now when I display the attached devices I just see some odd names with IP and MAC addresses.
