packetwerks
Apr 02, 2018Star
v2.1.3.4
My Orbi autoupgraded to v.2.1.3.4 this morning and I found tht ethernet backhaul no longer works. Is this expected behavior? Anyone else seeing this?
Apr 02, 2018Guru - Experienced User
Did you do a factory reset on both router and Satellite(s) then set up from scratch. Were seeing continued problems after the FW is updated and needs a full factory reset and set up again. Others have reported this and reported that after the reset, seems to clear the problems.
SOG1996wrote:The whole day wasted on trying to get my home netowrk back in business, this firmware is causing the router to reboot every 2-3 minutes. we definitly need the option in the app to stop auto update in the ORBI routers and Satelites
SOG1996
Apr 02, 2018Aspirant
I did not wanted to do it at first because I label every device that connects to my network 120 of them, but as last resource I did reset the router & Satelite juts to find out it did not make any difference, router kept rebooting every 2-3 minutes, I fell back to V2.0.1.4 but I know it I will get the auto update some time in the near future.
- FURRYe38Apr 02, 2018Guru - Experienced User
So is v2.0.1.4 working with out any problems?
When you did the factory reset on v2.1.3.4, did you set up from scratch or apply a saved config file?
SOG1996wrote:I did not wanted to do it at first because I label every device that connects to my network 120 of them, but as last resource I did reset the router & Satelite juts to find out it did not make any difference, router kept rebooting every 2-3 minutes, I fell back to V2.0.1.4 but I know it I will get the auto update some time in the near future.
- SOG1996Apr 02, 2018Aspirant
from scratch, went thru the whole thing, entering the App admin ID/PSW, the ssid and netowok psw, I had to set up my guest network, and like I said before I lost all the set up I had where I label each devide , now when I display the attached devices I just see some odd names with IP and MAC addresses.
There device detection maybe not fully working. I have noticed same Unknown naming of some devices. I presume there name some handshaking problems between the FW and the devices themselves.
Do your devices have host names assigned manually? I know some may not however if you give a name, the router should beable to show the host name.
Also is the same thing seen on different browsers? IE11, FF or Opera?
