In5iDi0uZ
Jul 22, 2019Guide
V2.3.5.30 Broke Bridge Mode Dont Upgrade
Frustrating weekend troubleshooting. I use Orbi RBR50 and a RBS50 also use a R7000 in Bridge mode for my pc, using 5GHz, for last couple years. I had updated the Orbi and the R7000. After this It wo...
In5iDi0uZ
Jul 22, 2019Guide
Yes, I always factory reset whenever I upgrade firmware.
Jul 22, 2019Guru - Experienced User
I would let NG know if you can. Seems like you did everything and found a problem.
Only other test I would have tried is disabling WPA altogther on the RBR to just check to see if the R7000 connected to the RBR while in the open. Hopefully NG can check this and fix it.
