In5iDi0uZ
Jul 22, 2019Guide
V2.3.5.30 Broke Bridge Mode Dont Upgrade
Frustrating weekend troubleshooting. I use Orbi RBR50 and a RBS50 also use a R7000 in Bridge mode for my pc, using 5GHz, for last couple years. I had updated the Orbi and the R7000. After this It wo...
In5iDi0uZ
Oct 09, 2019Guide
Welp. Netgear decided to auto-update my firmware to 2.3.5.30 and it broke my r7000 bridgemode again. Everything else connects fine to the Orbi. I also forgot to mention that I bought a new r7000 around the last time i was having issues. I now downgraded to 2.3.1.44 and it is working fine. How do i disable auto-update on the Orbi?
Retired_Member
Oct 09, 2019
In5iDi0uZ wrote:How do i disable auto-update on the Orbi?
You don't.
In5iDi0uZ wrote:Welp. Netgear decided to auto-update my firmware to 2.3.5.30 and it broke my r7000 bridgemode again. Everything else connects fine to the Orbi. I also forgot to mention that I bought a new r7000 around the last time i was having issues. I now downgraded to 2.3.1.44 and it is working fine. How do i disable auto-update on the Orbi?
- Ragar99Oct 09, 2019Luminary
You genuises previsouly said one could prevent auto upgrade. Some rhetoric about only for minor releases, though specific details never quite got posted.
- Retired_MemberOct 09, 2019
Ragar99 wrote:You genuises previsouly said one could prevent auto upgrade. Some rhetoric about only for minor releases, though specific details never quite got posted.
As far as I know you can't. Check your router at the login screen. According to NG, the only FW that is auto pushed (no action required by user) are those with major updates.
