ar9
Aug 22, 2019Aspirant
V2.3.5.30 Upgrade Has Been A Disaster
I have an Orbi router with three satellites all connected with Backhaul status "Good". Our experience has been touch and go with the Orbi with Satellites and device connections dropping intermittentl...
RipInGlendale
Sep 13, 2019Aspirant
I see a common theme here, in other posts, and Googling. My symptoms are similar. Satellite repeatedly disconnects and reconnects. It didn't before the v2.3.5.30 upgrade. I didn't upgrade the satellite first, unfortunately, and didn't see anything in the manual suggesting to do so. If that's "the issue," I'm not sure I know how to rectify it. I upgraded because I received an email from Netgear saying this was an important security update and I'm concerned about security, but why I or anyone else updates firmware is irrelevant, so please stop bringing that up. It doesn't help even a little. This is an expensive mesh network solution for home use and a firmware upgrade should work much better.
RipInGlendale
Wasn’t able to connect strictly to the satellite via Ethernet...maybe because I had setup as AP? But resetting both router and satellite, setting everything back up in router mode and then switching back to AP seems to be working so far. Connected my laptop to the satellite via Ethernet again and ran Net Uptime Monitor for three hours and it logged no failures. Still a pretty unsettling experience.
- FURRYe38Sep 14, 2019Guru - Experienced User
So where you able to update the FW on the RBS?
