Vaslo
Nov 06, 2019Guide
v2.5.0.38 is horrible and making my RBS satellite go out intermittently
Just want to post as well since I don't think management is getting the hint - since upgrading to v2.5.0.38, my RBS satellite just will not stay connected. I tried unplugging, rebooting, and resetti...
CrimpOn
Nov 06, 2019Guru - Experienced User
Vaslo wrote:Just want to post as well since I don't think management is getting the hint - since upgrading to v2.5.0.38, my RBS satellite just will not stay connected. I tried unplugging, rebooting, and resetting the whole thing and after all that wasted time, it's still not working. I am 100% sure it's the firmware since it started immediately after the upgrade. Can I roll back? Are you going to issue a fix? It is clearly a bad update and needs to be addressed before you work on any other issues.
Alas, my impession is (a) no actual Netgear Engineers participate in the community forum, and (b) I am pretty certain that people have been roasted over the problems with 2.5.0.38. Where that fits in management's priorities is anybody's guess.
As FURRYe38 mentioned, what most people are doing is installing the previous firmware, 2.3.5.30. Download the zip files from the Netgear support web site. Unzip them. Log onto the Orbi web interface (for the satellite first, then the router), and do a "Manual Update."
https://kb.netgear.com/000061080/RBR50-RBS50-Firmware-Version-2-3-5-30
