Vaslo
Nov 06, 2019Guide
v2.5.0.38 is horrible and making my RBS satellite go out intermittently
Just want to post as well since I don't think management is getting the hint - since upgrading to v2.5.0.38, my RBS satellite just will not stay connected. I tried unplugging, rebooting, and resetti...
Vaslo
Nov 06, 2019Guide
Thanks for the checklist but I'm 110% sure it's the firmware - so I don't think I need to check those other things. Satellite and Router were on same version - v2.5.0.38, dont have many neighbors, signal was very strong literally until the following minute of updating the firmware, which is when we started having issues and spend several hours trying to reboot, reset, fix, etc.
I just got it manually downgraded on the Satellite with v2.5.0.30, and I already see improvement. However, when I try to manually upgrade the router following the satellite, I keep seeing:
500 Internal Server Error
It seems to be working better but now the router and satellite are different firmware versions, and I read that's a no-no.
Retired_Member
Nov 06, 2019Yes all should be on the same firmware.
