Josh12345
Jan 05, 2023Aspirant
V2.7.4.24 "No Internet" until hard reboot?
Hi - My Orbi's have been working great for years, but it seems that with this latest update about every couple weeks the router reports "Internet Status: Offline". I've troubleshot this with...
CrimpOn
Jan 05, 2023Guru - Experienced User
Josh12345 wrote:
To fix it, I need to unplug the router plus all the satellites, and then plug the Orbi router back in, allow it to boot up, and then plug in the satellites. I'm not really sure if this is a consistent fix, or just the last thing I tried.
It's probably not necessary to mess with cables. Just power off the router using the switch on the back. Sing "Mary had a little...". Then power it back up again.
The next time it happens, could you try clicking the "Test" button?
It might be helpful to make a backup of the router configuration. There is a quick Factory Reset procedure:
- Do the paperclip reset thing.
- When the router boots up with credentials "admin" and "password", go through the setup, but do not change anything.
Leave the default WiFi SSID/password. Do not "register". Do not enable anything (Armor, Parental Controls). - When you get to a screen offering two choices (a) load a saved configuration, or (b) continue manual setup,
Select (a). Browse to the location on your computer where the configuration file was saved, and select it. - When the router reboots, the entire configuration will be restored.
- Takes 10-15 minutes and guarantees "no typos".
- Josh12345Jan 05, 2023Aspirant
CrimpOn Thanks for the guidance re: the on/off switch. Can do. Is "Mary had a little lamb..." necessary? If I sang "London bridges falling down..." would it still work? I'll do the experiment and report back... Science! đ
When it happened last month, I hit the 'Test' button shown in your post. I don't recall if it fixed it or not - I don't think it did, but will try if/when it happens again & report back
Thank you very much for the tip about quick Factory Resets! I use a number of reserved IP addresses and port-forwarding controls that I've gotten quite good at setting up after doing it again and again after factory resets while troubleshooting. However, I admit to getting a smidge cranky about it. This will be very helpful.
Is there anything that I could do to prevent it from going offline entirely vs fixing it after it has decided to go offline?
Until next time..
Josh
- CrimpOnJan 05, 2023Guru - Experienced User
Since the router is not supposed to do this, I have no advice about how to prevent it from doing so.
Just for curiosity, is the system actually "off line" when this happens? i.e. it is one thing for the Orbi app (or the web interface) to complain about "no internet" and an entirely different thing if the problem is that some specific IP address cannot be reached by the router and it is unhappy about it.
Do all user devices also stop working when this happens? Can a device still ping an internet IP address, such as 1.1.1.1 or 8.8.8.8?
- Josh12345Jan 13, 2023AspirantInterestingly, no, I don't think it is truly offline even if the interface says it is offline. While it is true that none of the devices on the network can ping 8.8.8.8 (I tried), my ISP support rep said that they can see a Netgear device appear as connected to their provided gateway after I plugged the CAT5 cable back in. This leads me to think it was a firmware issue - but that's as far as I got in thinking about that before posting to this forum...
