stevenhar
Jan 29, 2025Star
v2.7.5.6 more unstable?
Since updating to the latest firmware v2.7.5.6 for RBR50 / RBS50 I've noticed at least two crashes, there may have been more. Has anyone else noticed increased instability since updating from v2....
Jan 29, 2025Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- stevenharJan 29, 2025Star
Had another restart, so definitely something not right.
I have just tried the full system reboot, will monitor and try factory reset + restore if its still an issue.
- FURRYe38Jan 29, 2025Guru - Experienced User
If the FR and setup from scratch fails, then might revert back to prior working version of FW.
