stevenhar
Jan 29, 2025Star
v2.7.5.6 more unstable?
Since updating to the latest firmware v2.7.5.6 for RBR50 / RBS50 I've noticed at least two crashes, there may have been more. Has anyone else noticed increased instability since updating from v2....
Jan 29, 2025Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
stevenhar
Jan 29, 2025Star
Had another restart, so definitely something not right.
I have just tried the full system reboot, will monitor and try factory reset + restore if its still an issue.
- FURRYe38Jan 29, 2025Guru - Experienced User
If the FR and setup from scratch fails, then might revert back to prior working version of FW.
