stevenhar
Jan 29, 2025Star
v2.7.5.6 more unstable?
Since updating to the latest firmware v2.7.5.6 for RBR50 / RBS50 I've noticed at least two crashes, there may have been more. Has anyone else noticed increased instability since updating from v2....
Jan 31, 2025Guru - Experienced User
If the Factory Reset and setup from scratch fails, then might revert back to prior working version of FW.
Joelcc wrote:
I have an RBR50 + 2xRBS50 and also experience almost-daily network disconnects since upgrading to 2.7.5.6
I've tried all the usual reboot steps including my fiber modem and powering each NetGear device one at a time slowly.
Doesn't seem to help. I now regret applying the firmware update.
Warning to others: Don't upgrade unless you need to. If it's not broken, don't upgrade.
stevenhar
Feb 03, 2025Star
Reverted to V2.7.5.4 and no problem since, so clearly a serious issue with the V2.7.5.6.
- FURRYe38Feb 05, 2025Guru - Experienced User
Since this series is EoL and newer FW may not be the best, you might give Voxels FW a go. I've had his on my 50 series years ago. Worked well. Enjoyed that you could add some other features to the system.
Good Luck.
