WKiek
Oct 12, 2020Aspirant
Vacuüm cleaner
Dear All, I own a Netgear Orbi RBR V2. It normally functions very well and I am happy with the purchase 5 months ago. However, everytime I use the vacuum cleaner, the internet connection goes dow...
CrimpOn
Dec 05, 2020Guru - Experienced User
WKiek wrote:I own a Netgear Orbi RBR V2. It normally functions very well and I am happy with the purchase 5 months ago. However, everytime I use the vacuum cleaner, the internet connection goes down (wifi is still up). After a system reset everything goed back to normal. How do I fix this?
Is the Orbi isolated from the house electrical supply with a UPS that has RFI/EMI filtering?
Does this happen no matter where in the house the vacuum is used, or only when plugged into certain electrical outlets?
