Shannon88
Aug 23, 2020Aspirant
Verizon FIOS G3100 Ethernet Only with Orbi RBR50
Had an Orbi with Xfinity router (used as a bridge) with both coax and Ethernet ports. Worked great. Today got Verizon FIOS with G3100 router. Technician set up with only an Ethernet cable from the wa...
- Aug 24, 2020
Thank you! After a night's sleep, I decided to use a paperclip to reset the Orbi and now all is working well. Thank you!
