capsnumber1
Jan 02, 2020Aspirant
Verizon FiOS Quantum Gateway Router Orbi RBK53 Issues
Hello All, Hoping someone can share some insight here. I've hooked up my Orbi router as the primary gateway (connected directly to FiOS) and everything works fine EXCEPT for my channel guide and...
Jan 02, 2020Guru - Experienced User
here's what you're effectively doing:
https://kb.netgear.com/30186/What-is-Double-NAT
it can cause many issues. Especially with devices that need to act as a router to run vod services.
What I'd do to get everything working?
Hook it up like this:
Fios gateway------>quantum router in router mode------->Orbi but with orbi in AP mode.
You do lose some of the functions of your orbi with it being in AP mode but you'll retain the wifi and switch capabilities all while being able to use the VOD/guide for the quantum.
I would recommend turning off the wireless on the quantum so it doesn't interfere with the orbi.
- capsnumber1Jan 02, 2020Aspirant
Thanks...ideally I would like the Orbi to be the primary router so my internet traffic is not funneling through two devices. VOD and channel guide aren't very important which is why I've tried to configure it this way. What I don't understand is why it worked fine with the Nighthawk router but won't work with the Orbi. I'm curious as to if anyone got it to work the way I have it configured and how.
- plemansJan 02, 2020Guru - Experienced User
maybe the quantum router has an AP mode.
it probably appears shortly on the orbi list until it recognizes its using the same subnet and then auto-reconfigures for a different subnet.
