teddytheo
Mar 29, 2020Follower
Verizon Fios Router G3100 Compatibility with Orbi
I am setting up new Verizon Fios tv and internet service. The router they provide is now the G3100 wifi 6 router. It says "This product is only compatible with the Fios Home Wi-Fi Extender (Model...
Mar 29, 2020Guru - Experienced User
Should be however your FIOS modem/ONT already has a built in router. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
