Yld2rob
Jan 25, 2017Luminary
Verizon FIOS Working settings
Is anyone using Orbi with FIOS and direct connection? In other words, you are not using the Orbi in AP mode with a Verizon Wireless router/gateway. If so, and do not have any disconnect issues, could...
st_shaw
Jan 25, 2017Master
Not sure if this is what you are looking for, but I can give you a link explaining how to setup your FiOS router into bridge mode. There are no FiOS settings involved once your do this, as the router simply bridges the Internet to the router. I just set this up with another router, but it's not an Orbi. Works fine.
