SK40
Sep 02, 2016Follower
Verizon Fios
Is it compatible with Verizon Fios?
GadgetGuy
Oct 01, 2016Apprentice
NETGEAR has a great Fios-Orbi help page now.
It worked very well. I'm getting over 150 all over the house. More than I'm paying for'
The ROI is pretty good. Even without a guest network. And I'm sure they will arrive eventually. I had almost zero reception outside the 'router room'--now I have 100% all over the house.
- itGeeksOct 01, 2016Apprentice
That is great info for anyone with FiOs or any other provider that reqwires there router stay in place to provide TV/Phone service but I just want to point out that is only one way of doing it the other way and the way I prefer is to hang Orbi or any other 3rd party router off a DMZ on the service providers router and setup my internal network on a diffrent subnet, As we know these ISP's have remote access to there routers and I for one don't want prying eys into my network. It has also been reported by others that hanging the FiOs router off our 3rd party router on a DMZ also works fine and does not break any of the FiOs services but I have not tested this YET but I will soon, This would be a better option if it works for anyone wanting to use VPN.
- TheEtherOct 01, 2016Guru
Look at the link to the FAQ. There are several options for setting things up. Each has its pros and cons.
