TerryKeating4
Apr 09, 2023Follower
Verizon LTE Network Extender blocked by Orbi RBR20
Router is Orbi RBR20. What factory setting needs to be changed?
1 Reply
- KevinLiTNETGEAR Moderator
Hello TerryKeating4,
I understand that you are not able to integrate your Verizon LTE Network Extender into your RBR20. The RBR20 Orbi Mesh System router has been designed for full compatibility with RBS10, RBS20, RBS30, RBS40, and RBS50. To integrate LTE with your existing network it is recommended that you use the LBR20 with your existing satellites. The LBR20 will enable your network to use the LTE network for redundancy.
Please navigate to the link below for additional information about the LBR20 automatic failover feature:
Orbi LTE Router (netgear.com) (page 21)
Please navigate to the link below for more information about the LBR20:
Orbi LBR20: 4G LTE Tri-band WiFi Router | NETGEAR
Best,
Kevin
Community Team
