tony12257
Sep 26, 2019Aspirant
Verizon orbi rbk50
Ok I have the orbi rbk50 from Verizon is there a way to flash netgear stock firmware?
michaelkenward
Oct 03, 2019Guru - Experienced User
As CrimpOn says, this seems to be as designed.
There may be a hacker out there somewhere who has worked out how to Telnet into the router and to change it. This seems to be easier on Netgear's non-Orbi kit, but you never know.
tony12257
Oct 03, 2019Aspirant
I was thinking about using the tftp server
- CrimpOnOct 03, 2019Guru - Experienced User
One user reported trying to tftp Netgear firmware to an Orbi router and said it "bricked" the router.
If it is working now and you brick it, then (a) you have no internet, and (b) Verizon may figure it out and refuse warranty coverage.
It is indeed frustrating that products sold through suppliers do not get the same update attention as products "sold direct." Cell phones are a good example. Phone company updates always lag behind manufacturer's updates (or never come at all).
- Retired_MemberOct 03, 2019
CrimpOn wrote:One user reported trying to tftp Netgear firmware to an Orbi router and said it "bricked" the router.
Another reason to stay away fromm Verizon internet
- tony12257Oct 03, 2019AspirantThanks for that information
