jp4120's avatar
jp4120
Guide
Jan 24, 2020
Verizon vs Comcast connecting to ORBI
purchased from Amazon as RBK33 (base and 2 satellites) but manual refers to it as a RBR40
my satellites are RBW30 - each are currently $142 on Amazon - but they sell the base router and 2 satellites for $290 less $30 coupon.
I am currently using Comcast 1gb service with a  Comcast modem/router with the router bypassed - all is working pretty well.
trying to drastically reduce all my high ($270 per month) comcast price gouging bills
dropped all tv - comcast internet only 1gb for $105/mth plus youtube tv for another $50/mth - total $155/mth
however verizon will do the same speed for $80/mth - along with youtube tv it would total $130/mth
Has anyone switched to Verizon?  Verizon customer service tells me since i am only getting internet - there is no need for a modem - only an ethernet cable from the OMT box will plug directly into ORBI system.
i would think i would want a modem or a splitter or something since i would want to hard wire my desktop PC since that sits right next to main ORBI box.
anyone have any feedback on this situation?
  • Good it's all working. Please mark your thread as solved so others will know.
    Enjoy. :smileywink:
  • FURRYe38's avatar
    Some ISPs have specific HW requirements for getting internet to customers. Verizon mostly use ONTs to convert there services from fiber optic to LAN cable RJ45 that Orbi needs to communicate with ISP services. Verizon doesn't use cable modems or any modems on there service. So connecting up the Orbi to the ONT would all that would be needed.
    • jp4120's avatar
      jp4120
      Guide
      i may just stay with Comcast and not switch to Verizon.
      Any recommendations s on best modem to purchase for 1gb service if i stay with comcast ?- i am renting a Technicolor from Comcast but thinking i should buy one and save $14 per month/$168 year.
      I would want to keep the ability to hard wire a desktop PC into the modem - while connecting Orbi to another connecton.
      • FURRYe38's avatar
        See if CC supports NG's CM1100. I love mine on a 1G service. And you can connect two routers behind it. :smileyvery-happy:
