Ninovan's avatar
Jun 14, 2020
Vertical coverage problems
Our SoHo business is in a small cottage type house, barely 1,800 sq.ft. Problem is it is 3 floors. (Basement, main floor and attic space)  Our coverage for the third floor (attic) is slowly getting worse.
Our neiborhood is very congested WiFi wise...
Our base unit is in the basement, all the way to one side...
the Attic station is as far to the other side of the house as we can put it.
verticle distance is about 30', Horizontal distance is about 60'.
we have routine drop outs, and then it will clock in at 150Meg...
My partner is begging me to run a hardline.
I need some help, ideas, suggestions, something....
The  diagnostics available on the Orbi are nonexistent, and Netgear is useless for support.  I am very close to tossing it out and trying something new that has support, or at least some diagnostics...
  • FURRYe38's avatar
    Get the Orbi RBR base out from the basement and on to the the main floor. Basements are not good places for wifi routers. Concrete and steel will inhibit good signal travel.
    Also try turning down the power output of the RBRs wifi radios from 100% to 75-50% and see if this changes anything if you are in a wifi congested area. Under Advanced Tab/Advanced Settings/Wireless Settings
    • Ninovan's avatar
      Ninovan
      Star
      We are on on Comcast with a Arris Surfboard SB6190 and 300/12Mbps
      I switched to channel 11 and 44
      my "Backhaul" on the flakey satalite is "Poor" and is toggling between 2.4 and 5G
      The basement is where all the servers are and we have access...
      we have limited paths between floors as no closets line up, the stairway is not straight, and the perimeter was foamed so trying to snake something would be difficult. May have to go outside to run a hard line.
      right now we have the base in the basement, a satalite at the other end of the basement because that workstation has no wifi option. The other satalite is in the attic, and that is the one with poor backhaul.
      can I put a repeater on the 1st floor to help the backhaul?
      as I said, the attic goes between no connection and 180M...
      • FURRYe38's avatar
        Basements are not recommended locations for any wifi routers. Concrete and steel will cause problems for wifi singles. Main floor or 2nd level are recommended locations for main wifi routers.
