mwfast
Dec 30, 2023Follower
Very poor signal strength
I have a Ring Doorbell at my front gate and the WiFi signal has just become very weak there. What is the routine for re booting the system. I use Apple iPhone. My system is : Orbi92, Router RBR40 a...
Dec 30, 2023Guru - Experienced User
Try power cycling the system OFF for 1 minute then back ON.
- CrimpOnDec 30, 2023Guru - Experienced User
It might be useful to more details about the situation, such as:
- Which specific model of Ring doorbell is this?
- What is the distance between the Ring and the Orbi units in the house?
- How was it determined that signal strength has "become weak:?
Does the Ring app report WiFi strength? (I do not have a Ring) - Has anything "changed" about the installation? WiFi can be sensitive to obstacles in the direct radio path between devices. Moving a WiFi unit just a few feet can affect signal strength.
- Does the Ring no longer function?
Thanks
