pland10
Aug 24, 2024Aspirant
Very slow rbr50
I have had Orbi for some time. About a month ago it stopped performing. I am getting in the 90s download and low double digits on upload. I've reset everything in the house and I can't see any benefi...
- Aug 24, 2024
OK, I feel very stupid but sharing this with everyone. I have had the issue for a while. Something changed along the way. Anyways .. . . ..
I thought I had my orbi satellite connected via ethernet from the RBR50 router. However, instead the wire went from the fios router to the fios wifi extender then to the satellite. Something is off on the extender. I am thinking that it went bad.
I changed the cable to go from orbi router to satellite and all the issues went away. Someone on another post said to check the connections first. Well, I did that after posting my question.
Thanks to all the prior posts.
pland10
Aug 27, 2024Guru - Experienced User
Glad you got it figured out.
How RBS should be ethernet connected to the RBR for proper operation:
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System 📡 ‌‌🛰️
Enjoy.
