Rustyrankin2213
Dec 23, 2021Guide
Very slow Wi-Fi after update today
Hi guys got a rbr750 with 4 sats. Was getting 600-700mb over Wi-Fi very happy, today I’ve updated the firmware now I’m getting 30-40 if I’m lucky Any ideas
- Dec 29, 2021It’s seems to have sorted its self out I switched everything of and back on
Dec 23, 2021Guru - Experienced User
are you testing over 2.4ghz or 5ghz?
Maybe the new update has your device on the 2.4ghz now.
2.4ghz is much slower and sensitive to interference
- Rustyrankin2213Dec 24, 2021Guide
hi plemans
how would i check?
- plemansDec 24, 2021Guru - Experienced User
Look on the device you're testing on. Some will tell you.
Or you can look in the orbi attached devices page. I think that tells you as well.
