Rustyrankin2213
Dec 23, 2021Guide
Very slow Wi-Fi after update today
Hi guys got a rbr750 with 4 sats. Was getting 600-700mb over Wi-Fi very happy, today I’ve updated the firmware now I’m getting 30-40 if I’m lucky Any ideas
- Dec 29, 2021It’s seems to have sorted its self out I switched everything of and back on
Dec 23, 2021Guru - Experienced User
are you testing over 2.4ghz or 5ghz?
Maybe the new update has your device on the 2.4ghz now.
2.4ghz is much slower and sensitive to interference
Rustyrankin2213
Dec 24, 2021Guide
hi plemans
how would i check?
- plemansDec 24, 2021Guru - Experienced User
Look on the device you're testing on. Some will tell you.
Or you can look in the orbi attached devices page. I think that tells you as well.
