Rustyrankin2213
Dec 23, 2021Guide
Very slow Wi-Fi after update today
Hi guys got a rbr750 with 4 sats. Was getting 600-700mb over Wi-Fi very happy, today I’ve updated the firmware now I’m getting 30-40 if I’m lucky Any ideas
- Dec 29, 2021It’s seems to have sorted its self out I switched everything of and back on
Dec 28, 2021Guru - Experienced User
Please make a new post and we'll try and help you out. The RBK7 series differs from the CAX80.
Thank you.
econgolf wrote:
I'm dealing with the same exact issue with the CAX-80. Used to get 400MBPS, now getting 30-60 after the udpate. Wondering if it's the same root cause?
Rustyrankin2213
Dec 29, 2021Guide
- plemansDec 29, 2021Guru - Experienced User
Glad you got it sorted out with an easy fix!
- FURRYe38Dec 29, 2021Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
