Richards95
Apr 25, 2022Aspirant
Very slow Wi-Fi with Orbi RBR20
Hello, Since I moved to my new house I got a very unstable and slow Wi-Fi connection/network. The strange thing is that with my Wi-Fi of the actual service provider the connection is way better. ...
Apr 25, 2022Guru - Experienced User
You put, "when you switch" to your isp's service. Are you saying the ISP's router?
What modem/gateway is it connected to?
If it has its own integrated router, its causing a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
