flash99
Nov 11, 2017Initiate
Very slow wired speed
I have an Orbi with one satellite running latest firmware. No QOS or other non-usual settings. When I copy between two wired devices, one of them connected to the main unit and the other to the sate...
epsilonkore
Mar 07, 2018Apprentice
I will post soon. When I bought it from Costco it came with 1.X firmware (which version of 1.X I am not sure). Soon after it auto updated to 2.0.X and later to 2.1 which is when i started having so many issues I had to roll back to 2.0.1.4. It was during 2.1 that I noticed the WAN to LAN speed being so greatly reduced, so when I rolled back to 2.0.1.4 I hoped it wouldl fix it. It did not. While I cant reproduce my performance from December's original unboxing, I can show that SmallNetBuilder ran performance benchmarks showing that it was hitting int he 924Mbps range in thier labs. (not sure if this link will copy on this forum, but the benchmarks are halfway down under WAN-LAN) TCP https://www.smallnetbuilder.com/wireless/wireless-reviews/33028-netgear-orbi-reviewed?showall=&start=1
Mar 07, 2018Guru - Experienced User
Ok, this is something to bring to the attention of NG support. You might see if a v1.x FW is still available to test with...
epsilonkorewrote:I will post soon. When I bought it from Costco it came with 1.X firmware (which version of 1.X I am not sure). Soon after it auto updated to 2.0.X and later to 2.1 which is when i started having so many issues I had to roll back to 2.0.1.4. It was during 2.1 that I noticed the WAN to LAN speed being so greatly reduced, so when I rolled back to 2.0.1.4 I hoped it wouldl fix it. It did not. While I cant reproduce my performance from December's original unboxing, I can show that SmallNetBuilder ran performance benchmarks showing that it was hitting int he 924Mbps range in thier labs. (not sure if this link will copy on this forum, but the benchmarks are halfway down under WAN-LAN) TCP https://www.smallnetbuilder.com/wireless/wireless-reviews/33028-netgear-orbi-reviewed?showall=&start=1
