TenKB
Apr 07, 2020Aspirant
Video conferencing network reconnects
I have an Orbi RBR50 with two satellites RBS50 in router mode. After a growing internet connection dropping issue (for which I read a number of community posts), I updated the firmware (2.5.1.8) on ...
ekhalil
Apr 14, 2020Master
TenKB wrote:...... Also, with it repeating that many times in one day, I doubt it would be a ISP lease issue.. Any thoughts?
What is your ISP lease time please? You can check this in the web GUI under >> ADVANCED >> ADVANCED Home >> INTERNET PORT >> CONNECTION STATUS >> Lease Obtained
TenKB
Apr 14, 2020Aspirant
Here is the lease information:
| Lease Obtained | 1 Days, 0 Hours, 0 Minutes |
| Lease Expires | 0 Days, 21 Hours, 31 Minutes |
- ekhalilApr 14, 2020Master
TenKB wrote:Here is the lease information:
Lease Obtained 1 Days, 0 Hours, 0 Minutes Lease Expires 0 Days, 21 Hours, 31 Minutes This is a long lease time, and it can be that Orbi is loosing the connection with the ISP and needs renewal of the lease more frequently.
This is a problem in Orbi since a long time and is still very obvious in the latest firmware.
You won't loose anything by trying to reduce the lease time. :)
- TenKBApr 17, 2020Aspirant
I went ahead and tried another mesh router system altogether. The issue persists.. So that takes Orbi out of the picture. I talked to the ISP.. they don't keep logs and will only troubleshoot as the issue is happening.. which is not long enough to get them on the phone..Is it worth trying another wireless modem at this point or chaulk this up to internet saturation due to the increased number of people at home these days..
