UkTerry
Jun 11, 2021Aspirant
ViginMedia Hub3 and Orbi r350 reboot
Hi I have a Virgin media HUB3 set-up in Modem only mode and an orbi rbr350 as the router connected to the hub3. I have recently had random reboots of the HUB3, I have checked the logs on the HU...
UkTerry
Jun 12, 2021Aspirant
Hi
I did that for a while, there was no reboots.
Previously I was using the Orbi as the router, and getting lots of DOS messages, and for some reason many DHCP requests even for IP's that were in the static list, no idea.
I have it set up now as in AP mode with the Virgin media HUB3 as the router / DHCP server.
Everything was running fine for 20 plus hours, until I used MS edge to brouse, the reboots that I have seen do seem to come when brousing via MS edge, this is strange.
I am now monitoring the up time of the Hub to see if any further reboots have happened when I have not been browsing.
Thank you for your suggestion.
Terry
