CmdrBond
Jul 21, 2020Aspirant
Virgin Media Hub 3.0 VMDG505/TG2492LG-VM and Orbi RBK50 - HELP!
I am trying to set up a new Orbi RBR50 onto my Hub 3.0 and I cannot get it to detect the internet. 1. I believe my Hub is successfully in modem mode as the light is solid magenta/red/whatever 2....
michaelkenward
Jul 26, 2020Guru - Experienced User
"I believe" isn't exactly reassuring.
Are you convinced that you are in modem mode.
I'm not sure that I follow the narrative here. Take this bit:
CmdrBond wrote:
But take the lead out of the laptop and plug it into the WAN port on the Orbi, and the Orbi refuses to see the internet connection. (Laptop directly connected to Ethernet port on orbi)
Do you mean that simply by plugging the laptop into the Orbi kills the Internet for everything?
I am having a bit of trouble working out what is plugged in where in this scenario.
