CmdrBond
Jul 21, 2020Aspirant
Virgin Media Hub 3.0 VMDG505/TG2492LG-VM and Orbi RBK50 - HELP!
I am trying to set up a new Orbi RBR50 onto my Hub 3.0 and I cannot get it to detect the internet. 1. I believe my Hub is successfully in modem mode as the light is solid magenta/red/whatever 2....
Jul 26, 2020Guru - Experienced User
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
2. Directly connecting port #4 (lowest) to my laptop gives my laptop internet.
2a. Doing an IPCONFIG /ALL shows the Ethernet adapter as follows:
Connection-specific DNS Suffix : cable.virginmedia.net
DHCP Enabled : Yes
IPv4 Address : 82.xxx.xxx.201 (redacted)
Default Gateway : 82.xxx.xxx.1 (redacted)
DHCP Server : 62.xxx.xxx.xxc (redacted)
DNS Servers : 194.168.4.100 and 194.168.8.100
So all seems well.
But take the lead out of the laptop and plug it into the WAN port on the Orbi, and the Orbi refuses to see the internet connection. (Laptop directly connected to Ethernet port on orbi)
Connecting via DHCP
