RichardCP
Sep 10, 2017Follower
Virgin Media Hub3 and Orbi
I live in quite a large (5 bed - 4 storey) Victorian house and currently have a Virgin Hub3 on the ground floor and one Netgear WN3000RP extender in an upstairs room. This is not sufficient for adeq...
Sep 11, 2017Guru - Experienced User
You can use Orbi as an AP (access point) with your existing Virgin Media Hub3. You could leave the Tivos connected to the media hub, or you could turn the hub3 wifi off, and just use Orbi.
Another option is that you could double-route (using the Orbi as a router behind the Virgin Media Hub3). That would let you use the routing features of the Orbi (for instance it's OpenVPN support). If you do that, it would be best to turn off the hub3 wifi.
