RichardCP
Sep 10, 2017Follower
Virgin Media Hub3 and Orbi
I live in quite a large (5 bed - 4 storey) Victorian house and currently have a Virgin Hub3 on the ground floor and one Netgear WN3000RP extender in an upstairs room. This is not sufficient for adeq...
Mar 10, 2018Guru - Experienced User
Glad it seems to be working better. Hoping next FW update will stablized it even more.
Yes, theres been issues with using SONOS devices. They seem to cause problems here and there.
You could try this, Enable the wifi on the HUB and set the channels on 2.4Ghz to far away from the Orbi, So if you set channel 11 on the Orbi, use channel 1 on the modem and connect the SONOS devices to the Modems wifi. You can always drop back and disable if something happens.
Ya, theres issues with Intel based modems:
koregan123
Mar 18, 2018Tutor
Oh brother here we go again!! - after about 2 days of decent wifi its started to fall apart again
i have setup my virgin media hub 3.0 in modem mode, disbled wifi, put the orbi’s ip address in the DMZ, downgraded the orbi firmware back to 2.0.1.4 manually, moved the sattelite within 25 feet with not even a wall inbetween, manually separated the orbi and sonos channels and the system drops regularly whether the sonos is switched on or not (worse when it is switched on)
my sattelite seems to drop probably once an hour when sonos is not on and connected to more often when it is. The wifi drops and i have to reboot some of the connected devices even when it comes back up to be able to reconnect (android phone and ipad)
I have read virtually everything i can on orbi, virgin and sonos forums and am a tad frustrated
my house is not that large (i live in london so our houses are pretty small) it has quite thick walls and my orbi and sonos boost base devices have to be in the kitchen where the broadband enters.
i have tried the system with no sonos plugged in and the sattelite still drops regularly as ive said
i know technology as i have a first class honours degree in software engineering, ive read posts on these forums saying ‘wifi is just like that’ or ‘be patient’ but i’m really not at all happy with netgear right now. This is supposed to ne a consumer configable wifi system. I can get a decent router for £50 but i chose to buy an over spec system so i got good wifi everywhere in my home for over £300 - it worked fine for probably 9 monhs then recently seems to have fallen apart and noone seems to have any idea why.
i would buy another system but im still hopeful that netgear will fix these issues or at least tell us what limitations there are in use. Noone told me that i could not use sonos, android devices, ios devices, hiuse my orbi next to a fridge etc. when i bought this system - is it really THAT sensitive?
is there any sign of a new firmware fix, something to give me faith anyone cares or is even working on this or do i just throw it away and attempt to start again with a different system?
i have powered everything down and switched it all on stage by stage leaving 10 minutes between for everything to stablise but to no avail.
if anyone can spot a basic ‘have you tried this’ that im missing please shout as im at.a loss as to what to try now - thanks guys
