RichardCP
Sep 10, 2017Follower
Virgin Media Hub3 and Orbi
I live in quite a large (5 bed - 4 storey) Victorian house and currently have a Virgin Hub3 on the ground floor and one Netgear WN3000RP extender in an upstairs room. This is not sufficient for adeq...
Mar 18, 2018Guru - Experienced User
How big is your house? Sq Ft?
koregan123
Mar 18, 2018Tutor
1400 sq feet over 2 floors
we have quite thick walls so i never found a router whose wifi signal would reach from our kitchen upstairs - i have the router in the kitchen and the sattelite in the stairwell which enables the wifi (when available) to reach upstairs and cover the whole house
the issue i have is not reach, its the fact that the sattelite appears to regularly drop and then it seems to get in a muddle (ie the ssid is visible but either my devices connect and i cannot get intenet access, it says the wifi password is incorrect or just hange when trying to connect and i have to reboot the connecting device and try again)
i have unplugged the sattelite for now and the wifi seems a bit more stable but obviously slower from another room and signal doesnt make it upstairs anymore)
i have unplugged the sonos completely for now - just trying to get a stable orbi before i connect anything else
i thought downgrading to 2.0.1.4 would at least fix the sattelite dropping issue i had but it doesnt seem to have at all
K
