RichardCP
Sep 10, 2017Follower
Virgin Media Hub3 and Orbi
I live in quite a large (5 bed - 4 storey) Victorian house and currently have a Virgin Hub3 on the ground floor and one Netgear WN3000RP extender in an upstairs room. This is not sufficient for adeq...
Mar 18, 2018Guru - Experienced User
Kitchen might not be a great place for the router. Microwaves and other devices could cause problems.
Stairwell isn't a great place either. Can you place the Satellite upstairs over where the router is downstairs?
1400 sq ft is kind of small and not really good for any additional Satellites. The main router will be able to cover most of this. Run the system with out the Satellite for a bit and see how it works for you.
koregan123
Mar 18, 2018Tutor
Thanks ill try the system with no sattelite although i have already noticed that upstairs bedrooms get minimal wifi and in some cases none - like i said we have quite thick walls (its probably marginally better than the linksys router i had there before which cost me like £80)
this does not explain why the sattelite keeps dropping when within 15 feet and within direct line of sight but that could be due to the kitchen etc. - funny but i had no problems with this for the first 9 months of having this setup -is there a way of checking firmware history so i can trace back to previous versions and see if there is a point the sattelite started being an issue?
ill probably ask the isp to change the access point in the building to avoid the kitchen and try again but that will cost and i already feel like ive been throwing money at something which will not be fixed. We will see
i understand that kitchen microwaves may have an impact as well as lots of electrical devices (fridges, wine cooler etc.) but interested in how the stair well is a poor place for a router - why so?
Thanks for ideas and feedback - just want to get my ‘wifi works’ life back
Never ever thought an expensive upgrade to my kit would cause such issues but you live and learn
K
- FURRYe38Mar 18, 2018Guru - Experienced User
Well the Satellites are designed to work probably over 15feet and best place 30 feet or greater maybe. Having the Satellite to close maybe cuasing problems.
Any other wifi neighbors near by? if so, how many and what channesl are they using?
