RichardCP
Sep 10, 2017Follower
Virgin Media Hub3 and Orbi
 I live in quite a large (5 bed - 4 storey) Victorian house and currently have a Virgin Hub3 on the ground floor and one Netgear WN3000RP extender in an upstairs room.  This is not sufficient for adeq...
kiwi-rich
Sep 27, 2018Aspirant
Thanks for this. I recently upgraded my Virgin Hub 3.0 from the original 3.0 version when it died on me due to hardware failure and the latest firmware upgrade for this rebadged Arris box renders Modem Mode when combined with Orbi a no-go. I have had to leave the wifi on the Hub to ensure Internet is accessible. I will probably convert Orbi to an AP. Other than having one extra Wifi access point I have all the functionality of the previous infrastructure, but please be wary of so-called upgrades to software etc as in this case they had a material impact on the Virgin SH3 and Orbi combination.
Sep 27, 2018Guru - Experienced User
If you configure the Orbi for AP mode, then you can disable the wifi on the HUB. This is recommended as it can cause interferences with the Orbi wifi system and having other wifi signals in close range.
- DB2kSep 27, 2018AspirantAlthough bear in mind if you get an internet problem and your hub reboots you'll lose your wifi network and therefore local access, if you have your Orbi in AP mode.
- andrewjboswellSep 27, 2018TutorAdding to my previous reply about configuring Orbi with Virgin Hub by resetting both boxes, I just found out the Virgin hub is in modem mode, so wifi is off from that box.
 I recently purchased an HP Envy printer but I couldn’t use it as an AirPrint printer until I switched the Orbi Satellite off. The printer was treating it like a second network. Now the AirPrint works beautifully but the Orbi Satellite is banished to my garage. Money wasted.
- DB2kSep 27, 2018AspirantI mean.. sacrificing coverage around the house and garden so you can once a month print something off your phone seems harsh? Just move nearer the AP with the printer and then print - then they will be on the same AP no? Maybe raise a ticket on HP too as really it should just work?
- FURRYe38Sep 27, 2018Guru - Experienced UserDisable the Airprint on the HP printer and test the Orbi again...Orbi should work well if set up right.
- andrewjboswellSep 27, 2018TutorI bought the HP printer so I could use AirPrint. My point is that it doesn’t work with Orbi Satellite. Disabling Airprint isn’t an option.
- FURRYe38Sep 27, 2018Guru - Experienced UserWhat is the size of your home? Sq Ft?
 What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.Where was the printer in relation to distance from the router and satellite. If the printer if broadcasing its own wifi, this would cause interference with the Orbi Wifi. What channels is the printer using? Channels would need to be far and separate from the Orbis Wifi.
 You should contact HP about this and see if they have any information regarding there printer working with the Orbi.
 What channels are you using on the Orbi? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
 MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Disabling the wifi on the printer is only to see if it helps with the Orbi Wifi.
- andrewjboswellSep 27, 2018TutorThanks for your thoughtful reply. I have no problem with the Orbi satellite other than it prevents AirPrint from working. Apart from that it works fine. I was just posting here to help anyone else faced with the same issue. Thanks, Andrew
- FURRYe38Sep 27, 2018Guru - Experienced UserNot sure if any of these would be helpful:
