RichardCP
Sep 10, 2017Follower
Virgin Media Hub3 and Orbi
 I live in quite a large (5 bed - 4 storey) Victorian house and currently have a Virgin Hub3 on the ground floor and one Netgear WN3000RP extender in an upstairs room.  This is not sufficient for adeq...
Sep 27, 2018Guru - Experienced User
If you configure the Orbi for AP mode, then you can disable the wifi on the HUB. This is recommended as it can cause interferences with the Orbi wifi system and having other wifi signals in close range.
kiwi-rich wrote:
Thanks for this. I recently upgraded my Virgin Hub 3.0 from the original 3.0 version when it died on me due to hardware failure and the latest firmware upgrade for this rebadged Arris box renders Modem Mode when combined with Orbi a no-go. I have had to leave the wifi on the Hub to ensure Internet is accessible. I will probably convert Orbi to an AP. Other than having one extra Wifi access point I have all the functionality of the previous infrastructure, but please be wary of so-called upgrades to software etc as in this case they had a material impact on the Virgin SH3 and Orbi combination.
DB2k
Sep 27, 2018Aspirant
Although bear in mind if you get an internet problem and your hub reboots you'll lose your wifi network and therefore local access, if you have your Orbi in AP mode.
