dos286
Mar 29, 2020Aspirant
Virtual Mac Addresses with Nighthawk R9000 and Orbi
I have a list of static IP reservations on my Nighthawk R9000 router. My network server assigns access to certain resources based on IP address or in some cases MAC address of the connected devices. ...
Mar 29, 2020Guru - Experienced User
Be sure to know that STATIC IP addresses are set ON devices themselves while IP ADDRESS RESERVATIONS are set on host routers for connected devices. All you need if you want your devices to have an IP address that doesn't change is to set IP Reservations on the host router for each devices. Orbi only works as pass thru for devices. The Orbi should see connected devcies and there MAC addresses only.
dos286 wrote:I have a list of static IP reservations on my Nighthawk R9000 router. My network server assigns access to certain resources based on IP address or in some cases MAC address of the connected devices. This has worked fine for some time, however WIFI service was not reaching several rooms in the house. Having access to an ORBI router with 2 sattelites, I turned off the WIFI on the R9000 and added the ORBI in AP mode. Now devices connected to the ORBI do not list the real MAC address for the attached devices. My first question:
How can I make the ORBI report the correct MAC address for the attached devices?
If that is impossible, my next question is are the virtual MAC address assigned to attached devices stable? Will they change as devices move from the ORBI base unit to the satelites? Will they change overtime, or will the same device always be assigned the same virtual MAC address?
If they are not stable, how can I reserve static IP addresses to specific devices?
If static IP addresses are not possible, is there a better system recommended for my situation that can handel static IP addresses?
- dos286Mar 29, 2020Aspirant
Orbi Firmware: V2.5.1.8
R9000 Firmware: V1.0.5.8
It says that these are the latest.
Yes, that is the goal, to setup IP reservation on the router (R9000). The trouble is that reservation is done by MAC address, and suddenly devices to not have a consistent MAC address.
- CrimpOnMar 29, 2020Guru - Experienced User
I'd like to beat some more on this "dead horse". When the Orbi reports a MAC address, I'd like to distinguish between two scenarios:
- The MAC address is different from the MAC address that was reported before, but the MAC address reported by the device remains the same, and
- The MAC address reported by the device and reported by the Orbi match, but are different from the last time.
