hadwll
Feb 02, 2022Aspirant
Virtual machines cant reach router from host.
I am running a vm and am able to reach the 192.168.1.1 from it. however, I am unable to reach the same screen from my host. Is there anyone that could enlighten me as to why this is not posss...
hadwll
Feb 03, 2022Aspirant
Hi
Default gateway is the router.
CrimpOn
Feb 03, 2022Guru - Experienced User
The question was because the post appears to be inconsistent:
and
Both are able to ping the default gateway ok.
I wanted to confirm that the default gateway and 192.168.1.1 are the same IP address. If the gateway is 192.168.1.1, then both ost and VM can 'ping' 192.168.1.1 but only the vm can access the web page at 192.168.1.1.
That would lead me to suspect a problem with the VM, not a problem with the router.
